rear end questions
Old Apr 26, 2007 | 08:58 PM
pookey_03's Avatar
rear end questions
right now i have an open rear end with 273 gears. i want to know if i can swap in a posi with 373 gears? and also could i do it on my own?
Old Apr 26, 2007 | 09:13 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Re: rear end questions
Make sure that you buy the carrier and gears for the housing, buy a dial indicator to check run out, the extensions to measure pinion depth, and set a side a weekend if it is your first time. Take your time and you will be fine.
Old Apr 27, 2007 | 06:10 AM
ede's Avatar
ede
yes you can swap it, ys you can do it on your own. it'd be hard to tell how well or how poorly you'd do it, but yes you can do it. most people don't either because they're scared to try or don't have to required tols.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
