7.5 or 7.625
Old Apr 30, 2007 | 09:20 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
7.5 or 7.625
How do you tell the diference between the two?Am I correct in thinking gears are gears,its the carrier that determines if its limited slip or not?
Old Apr 30, 2007 | 10:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 7.5 or 7.625
Just with a measuring tape. The carriers are the same. The 7-5/8" gear is just slightly bigger than the 7-1/2"
Old May 1, 2007 | 09:59 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Re: 7.5 or 7.625
Am I correct in thinking I need thick gears that are for a 3.08 and numerically lower carrier,to fit my 10 bolt 2.73 limited slip stock gm rear?
Old May 1, 2007 | 11:16 PM
novatuc's Avatar
Car: 1984 Trans Am
Re: 7.5 or 7.625
You need the thick gears or a spacer to put numerically higher gears than 3.08 onto your series 2 carrier.
Old May 1, 2007 | 11:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 7.5 or 7.625
There's no functional difference between the 7.5 and 7.625.
F-body driver
Mar 6, 2023 11:44 AM
TexasMaro
Sep 15, 2015 06:50 PM
Numbah-1
Sep 12, 2015 08:57 PM
64Chief
Sep 12, 2015 08:05 AM
hectre13
Aug 26, 2015 08:17 AM
