Posi or not?
Old May 1, 2007 | 07:57 PM
90TSiAWD's Avatar
Car: '91
Engine: 3.1 V6
Axle/Gears: Unknown
Posi or not?
I have a 1987 Pontiac Formula they guy that sold it to me said it was posi but he is pretty stupid so I dont really believe him. So I went out and looked for the code on the inside axle tube passenger side but its caked pretty bad with grease and junk so I could'nt really see it. How do I tell if I count the bolts on the rear end housing and its a 9 bolt is it definatley a posi or not.
The guy said it has WS6 suspension and im pretty sure if it does it has posi but it has rear drum brakes so?? Anyways the car was originally a 305 TPI with a 5 Speed the motor has been switched to 350 nothing else changed.
Old May 1, 2007 | 08:03 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
Re: Posi or not?
if its a 9 bolt its prob a posi...go outside in the steet and do a burnout if thers 2 marks its posi and if its one its a open carrier.. thats the easiest way
Old May 1, 2007 | 08:06 PM
90TSiAWD's Avatar
Car: '91
Engine: 3.1 V6
Axle/Gears: Unknown
Re: Posi or not?
Yep I figured that was coming haha, well the other day I was backing into the driveway and my tires spun for a quick second but I couldnt tell if both were spinning, is posi engaged all the time or does it engage as soon as one of the tires start spinning?
Old May 1, 2007 | 08:10 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Posi or not?
if you don't want to waste your tires, just floor it on a rock driveway, and then go look at your tracks.
Old May 1, 2007 | 08:11 PM
90TSiAWD's Avatar
Car: '91
Engine: 3.1 V6
Axle/Gears: Unknown
Re: Posi or not?
My tires are bald anyways from the previous owner burning out all the time it looks like a pretty even tread wear.
Old May 1, 2007 | 08:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Posi or not?
thats not totally true, if you do a burnout with an open rear you do, most of the time, spin both rear tires. if you are turning and light them up, you will only spin 1. easiest way to tell is to jack up the rear of the car, put the car in neutral and turn one of the rear wheels. if they both spin the same way, posi, if they spin in different directions, open.
xgtharo86x's Avatar
Car: 86' Trans am
Re: Posi or not?
mines open carrier and both tires will spin in the rain,dirt or rocks lol...feels nice can wit to get posi!!
Old May 1, 2007 | 08:14 PM
90TSiAWD's Avatar
Car: '91
Engine: 3.1 V6
Axle/Gears: Unknown
Re: Posi or not?
Im gonna try that as soon as I get home for class tommorow seems like the easiest way to tell. Thanks.
Old May 1, 2007 | 11:39 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: Posi or not?
If the tires spin different directions it could also be a burnt up LSD. Not uncommon for 20 year old vehicles...
Just pop the cover and take a look at it, the oil is probably long long long loooonnnnnggggg past due for a change anyways!
Old May 3, 2007 | 08:56 AM
Shagwell's Avatar
Car: projects.......
Re: Posi or not?
- Trosional type posi units will let the tires spin opposite on jcak stands. They don't make a torsional for the 9-bolt, but it's still not a good "test".
Pull the cover and look. I'm sure it needs the fluid changed anyway.
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
