switch to a borg warner rear end??
Old May 3, 2007 | 04:09 PM
crazyirishguy's Avatar
Car: 1990 Iroc 5.7L
ok simple question i have 1990 iroc with stock rear with 3:23 gears in it and rear disc brakes and it just blew out on me, i am going to buy a rear out of a 1988 iroc with rear disc brakes and a borg warner with 3:42 gears and i am just wonderin if i will run into any trouble trying to put this in or if there is anything i should know before hand
i really dont know much about the borg warner rears ether so info about them would be nice and $250 that seems more than fair to me what do you guys think?
Old May 3, 2007 | 04:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: switch to a borg warner rear end??
Your 90 IROC may well have 11.7" rotors with alum PBR calipers. The 88 will have 10.5 rotors and Delco-Moraine iron calipers, which aren't very desireable. You could, however, swap the brakes from the 90 to the 88 with the correct backing plate. For info about that, check the following link:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Check the following link for info on the 9-bolt:
https://www.thirdgen.org/forums/faq-...now-about.html
JamesC
Old May 4, 2007 | 09:46 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I though the 9-bolt had 3.47 or some othe 'odd' ratio..
Old May 4, 2007 | 09:51 AM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Borg Warner 9-bolt has a 3.45 gear and is good and strong. My 9-bolt with 3.70's has held up fine behind my 383 for over three years now on the street and strip.
hectre13
Dec 11, 2023 08:14 AM
theshackle
Sep 17, 2020 08:26 AM
fasteddi
Sep 2, 2015 10:29 AM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
