Deep Trans Pan Help
Old May 4, 2007 | 11:54 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Deep Trans Pan Help
If you run a deeper pan on a TH350 (1 1/4" deeper), do you need some kind of filter exstension? Its 2qt extra deep pan and a TH350.
I searched and came up with results for 700r only. But quoted by TGO member TKOPerformance, "You dont need any kind of extension b/c the filter will still be submerged for a proprer dipstick reading". Does that apply to a TH350 also?
Old May 5, 2007 | 04:40 AM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
Re: Deep Trans Pan Help
I bought a B&M deep pan for my Th350 and it came with the filter extension.
I remember reading somewhere that you should have the extension. Can't remember where I read it?
Old May 5, 2007 | 03:40 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
The only filter extensions i have found are specific to certain B&M pans only. Mine is just a knockoff chrome plated steel pan.
Old May 5, 2007 | 05:26 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
One thing to keep in mind that chrome plated pan will retain more heat than the stock pan.Aluminum does a much better job of transferring heat(same goes for valve covers).
Old May 5, 2007 | 08:24 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Stuff should come with pan. Yes you need it. might as well weld up some scrapper plates too if your car is lower.
colton_carlson
Mar 8, 2019 12:21 PM
maroe624
Apr 16, 2017 08:29 AM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
