Speedo bypass for T56 swap?
Old May 5, 2007 | 12:38 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Car is a 1987 IROC with 700R4 and cable driven speedo. I am currently swapping in a 1996 T-56. I already have the SGI-5c box from Dakota Digital.
Most people who swap use an autometer speedo or whatever, then run the output from that through the SGI box and into the VSS cable. I'm wondering if I can bypass the speedo for now and just cut my VSS wire off the back of the stock speedo and run it straight to the output signal on the SGI box?
I'm planning on a complete dash swap to autometer gauges, but right now I just want to get the car up and running, even without any speedometer, then I can worry about swapping gauges later.
Thanks -- Aaron
Old May 7, 2007 | 09:48 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: Speedo bypass for T56 swap?
Not sure if that will work or not. Most people either have the tail shaft machined to accept a speedometer cable or use the Abbott cable X box which uses the electronic signal to turn the speedometer cable. I have one for sale if you're interested.
Old May 7, 2007 | 11:20 PM
Aaron_SK's Avatar
Nah, the entire dash panel is headed for eBay. I'm swapping in a full set of custom electric gauges once I get some cash. Just wondering if I can run the brown VSS wire right from the ECM into the Dakota Digital singal box.
Old May 21, 2007 | 01:41 AM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
how easy is it to convert from a cable driver speedo to an electronic one?
Old May 21, 2007 | 10:30 AM
vbMike's Avatar
I believe you have to swap out the whole gauge cluster.
Old May 22, 2007 | 12:06 AM
C.M.Jones's Avatar
Can someone be a little more Specific? I have a 84 non-computer controlled Z28 and I want to eventually put in the T56 but I want to get everything ready before hand like the speedometer
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
