Yet another speedo question
Old May 7, 2007 | 05:59 PM
Speedball's Avatar
Car: 1989 Camaro Iroc-Z
Hi folks. I have browsed for problems similar to mine but could not find any.
I have some problems with my speedometer. I have replaced the wire and gear in the transmission, but there are still no reading. I have checked to see if the speedometer works by rolling the backside of the speedo and it moves when I do that. Could it be problems that are further inside the tranny or could it be something else?
I screwed everything as tight as I should to the tranny, and the "clip" is connected in behind the speedo bundle. I still get the VSS code (code 24) but I assume that its because that the speedo is not reading anything. I also assume that replacing the VSS will not make the speedo work. What am I missing?
Help is accepted with gratitude.
Old May 8, 2007 | 05:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Yet another speedo question
Originally Posted by Speedball
What am I missing?
Perhaps the speedo cable itself has gone bad.
JamesC
Old May 8, 2007 | 07:04 AM
We'reNotWorthy's Avatar
I would check the cable and the if you still cant find the problem I would change the speedo.
Old May 8, 2007 | 10:21 AM
Speedball's Avatar
The speedo cable is brand new. But I can take a look at it again I guess. I guess the best thing to do is to remove the wire and check if its turning or not.
Old May 9, 2007 | 08:00 PM
Speedball's Avatar
Bah. I dont think I care anymore.
Car is for sale. Everything that is wrong with it is possible to find here. Just search for my posts.
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
beachrodder
Aug 7, 2015 04:27 PM
