REAR END ID
Old May 9, 2007 | 02:49 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
REAR END ID
Need some pictures, close and far of the entire rear end, with locations circled of the codes. A close up of what the code looks like is also helpful. And any general hints about what an axle and gear is. The rear end in question is a 9 bolt, disk brake, with a tag attached to the cover. Thanks.
Also, i need these soon, any help appreciated.
Old May 9, 2007 | 08:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: REAR END ID
All the info is on the tag.
Old May 9, 2007 | 08:16 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: REAR END ID
Would it tell you the ratio right on the tag? Or does it need to be decoded?
Old May 9, 2007 | 10:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: REAR END ID
It should be on the tag. If you know exactly what model it came out of, the TGO database will also tell you the ratio. If the cover has never been removed, it's time to change the oil. Once the cover is off, you can count the teeth to find the ratio.
Since it's been many years since these diffs were available, there's always a chance a previous owner has changed gears. Pulling the cover is the only 100% way to know what's inside.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
