Not Downshifting at correct RPM/Soft Shifts
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
After I took my 5.0 TBI out of my car and put the 350HO GMPP crate engine into it, I wondered if the transmission would need help. I put an edge TC on with a 2500-2800 stall as well. I got a new carburator as well, an edelbrock 1411(750cfm).
I got a Lokar TV cable, and adjusted it like I was supposed to. Didn't shift properly. I was told those aren't perfect, so I got a TVmadeEZ from Bowtie Overdrives.
New TV cable assembly with new spring to ensure I don't get the dreaded short spring syndrome. Adjusted it all over the place, moving the "adjustable cam" to get different shifts. Still doesn't downshift properly. At 35, it should shift into 1st, but just bogs. Same with second. Won't downshift properly to let the engine build up RPMs and take off.
Also, when I hold it to the floor, no matter what adjustment, the tranny holds the engine at 4500 or so RPMs while it takes a full second or two to shift. No quick shifts like before the engine swap. What has changed since I put the new engine in to take the shifts from firm to soft serve?
Re: Not Downshifting at correct RPM/Soft Shifts
FOUND OUT WHY... The "TV made EZ" cable doesn't work. The design makes the cable bind internally every time it's pulled by the throttle. Eventually, it binds so much it pretzels. When the knot tries to move up and down the shaft of the TV cable it gets stuck, and the cable no longer does its job. I've gotta get ahold of them and see if I can get a better quality item, or i'm goin back to the Lokar cable.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
any updates?
anytime you cant get the TV cable worked out give us a yell and we will help no matter where the trans came from www.performabuilt.com
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TheTraut88
Sep 7, 2015 05:22 PM
