parking problems
Old May 14, 2007 | 10:52 PM
jessc50's Avatar
Car: 88 supercharge Iroc Z,
parking problems
i got an 1987 iroc with a automatic transmmision when i put the traanyy in park it keeps goin like if it were in neutral it does not lock tranny runs good when driving havent had anny problems just that. what could be wrong is is my tranny gone. sometimes i push the shifter all the way up kind iof hard and it does lock what is wrong with it thanks
Old May 14, 2007 | 11:21 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Re: parking problems
I would try adjusting the cable that runs from your shifter in the car to the shift lever on the driver's side of the transmission. Hopefully that will solve the problem. It sounds like it's just not knocking the lever all the way into place on the transmission.
Old May 14, 2007 | 11:31 PM
jessc50's Avatar
how do you do that under the car or do you have to take of the center console thanks for the help hopefully is that
Old May 14, 2007 | 11:53 PM
racer J's Avatar
Engine: 305 TBI
It's a combination of both because you need to put the shift lever into a certain gear and then adjust the cable so that the console shifter matches. I think it's neutral but, I don't recall and my Chilton repair manual is across town. The last time I did it was when I was in high school and that was a long time ago. I do remember it's fairly easy and quick though.
Old May 26, 2007 | 11:36 AM
jessc50's Avatar
i tries adjusting it but im doin something wromg because it either stays in neutral,drive, reverse, or park what am i doin wrong???
Old May 26, 2007 | 10:54 PM
racer J's Avatar
Engine: 305 TBI
SHIFT CONTROL CABLE
Place the shifter in the car to Neutral.
Loosen the cable attachement on the bracket on the transmission.
Rotate the bracket on the transmission clockwise to the park position then back one click to Neutral.
Tighten the cable attachment to 11 ft-lbs of torque. The lever MUST be held out of park when torquing the nut.
SHIFT LINKAGE
Ubolt your cable from the bracket on the transmission.
Move the bracket on the transmission into Neutral.
Place your shifter in the car in Neutral.
Install the cable to the bracket on the transmission and adjust the cable so the pin has free movement.
Install and tighten the nut to the pin.
That should fix the issue if it's the shift cable causing it.
Old Jun 3, 2007 | 01:53 AM
jessc50's Avatar
the problem was that the cable snapped so i got to get new cable thanks for your help
Old Jun 6, 2007 | 02:41 AM
racer J's Avatar
Engine: 305 TBI
NP, glad you got it worked out. Where did the cable break at? I had the one in my 88 break down at the retaining point on the shifter linkage on the tranny. Had to rig it in place till I could get a new one. Lots of fun that was popping off.
Old Jun 8, 2007 | 02:03 AM
jessc50's Avatar
it broke by were the barcket thats on the tranny holds it in place it was fun but hopefully it doesnt break anymore
92camaroJoe
Jul 29, 2023 07:57 PM
Street Lethal
Apr 30, 2019 12:14 PM
db057
Sep 4, 2015 07:57 AM
92camaroJoe
Aug 13, 2015 06:07 AM
