Do you lose OD with a stall converter?
Subscribe
May 17, 2007 | 12:07 PM
I bought an 89 recently and it has a b and m 2800 stall in it, but the car never shifts into OD, my mechanic said the OD is in the torque converters, is this true? Is the only way to get the OD back is by getting the stock torque converter back in?
Reply 0
May 17, 2007 | 12:19 PM
Re: Do you lose OD with a stall converter?
Torque converters come in 2 ways. 1 lockup style used with a overdrive tranmssion. 2 non lockup and the transmission needs to be specificly set up for that converter and it has no lockup. Try and see if you can get some #'s off of the coverter and see what converter you really have. Also if the car isnt locking up it might be a computer problem.
Reply 0
May 17, 2007 | 12:24 PM
Quote: my mechanic said the OD is in the torque converters, is this true?
No, it's not true at all.
Reply 0
May 17, 2007 | 12:44 PM
You do not 'loose od' with a higher stall tc whether its lockup or not.
Though with a non lockup high stall TC you will loose some milage since that was the whole reason for having lockup.
Reply 0
May 18, 2007 | 11:11 AM
any idea why its not going into OD then?
Reply 0
May 18, 2007 | 11:16 AM
Haha, time to find a new mechanic.
Is the tranny in good shape? Fluid looks/smells ok? I'd check the little things first like making sure the shifter and TV cables have been adjusted properly, etc..
Reply 0
May 18, 2007 | 11:24 AM
Have you checked the TV cable adjustment?
Reply 0
May 18, 2007 | 01:00 PM
are we 10000000% sure that it still has the 700 in it and not a turbo 350. that would explain no overdrive.
Reply 0
May 18, 2007 | 01:27 PM
are we 10000000% sure that it still has the 700 in it and not a turbo 350. that would explain no overdrive.[/QUOTE]
i agree 100% with the above.
also make sure the tranny is not shifting to 4th.
the extra slip with the non locking coverter maybe fooling you. that would make alot more sense along the lines of what your mechanic may mean.
Reply 0
May 23, 2007 | 09:10 AM
I got to do some more testing to see if its shifting to 4th or not. Yes it is the 700r4, and yes the tv cable is adjusted correctly, and the fluid is fine.
Reply 0
May 30, 2007 | 09:49 PM
It IS shifting into 4th, but its not locking up. Also we can't get a reading on the computer cause the ecm is jerry rigged with two harnesses spliced together and neither reads. I think it might not be hooked up to the computer right maybe. There is also a mistery switch behind the shifter that seems non functional, it doesnt do anything as far as I can tell. My mechanic thinks that the converter doesnt have the lockup in it still. What reasons could be for it not locking up? I need to fix this im getting 12 mpg. It turns 3k at 65 mph
Reply 0
May 30, 2007 | 10:21 PM
Please email me at performabuilt@yahoo.com and ill take you through some checks and a fix,
Reply 0
May 30, 2007 | 11:47 PM
It has the jet chip too, it also used to be a tbi, but was converted to map tpi
Reply 0
Subscribe
