mech clutch bellhousing trans mounting position
Car: 1985 Trans Am
Engine: Chevrolet 355
Transmission: Borg Warner W.C. manual cog
Axle/Gears: B W 9-bolt 3.45 Limited Slip
I've located an 82 mech clutch bellhousing, but the trans mounts straight up not the 15 degree angle to the left. What about the angle of the shifter? ( My T-5 shifter would point to the right mounted straight up). What year bellhousing mounts the T-5 at an angle and is mechanical?( 83) only? Could you mount the trans straight up ,but modify the shifter?
BlackphantomZ28
Apr 24, 2016 08:14 AM
383backinblack
Aug 15, 2015 06:36 PM
