Clutch releases very high how do you fix that?
Old May 26, 2007 | 08:55 PM
z28chris's Avatar
Car: 86 z28 camaro
Engine: 305, 4 barrel carb
Transmission: T5 world class, stick
Axle/Gears: stock
I just finished rebuilding the whole engine, even put in new clutch and got the fly wheel machined. The whole car is great except that the clutch releases at the very end of the pedal. Is this normal? And if not how do you adjust it? It’s a hydraulic clutch and doesn’t have any adjustable nuts or anything I can find.
Old May 26, 2007 | 09:09 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
Re: Clutch releases very high how do you fix that?
need to bleed the clutch, just like you bleed brakes. hopefully u put the throw out bearing in right. hope this help
Old May 26, 2007 | 09:36 PM
z28chris's Avatar
Car: 86 z28 camaro
Axle/Gears: stock
I tried bleeding the clutch already and im pretty sure the release bearing is in correctly is there anything else that may cause it?
Old May 26, 2007 | 10:35 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Might help if we knew what kind it was..
Old May 27, 2007 | 12:05 PM
z28chris's Avatar
Car: 86 z28 camaro
Axle/Gears: stock
its a 86 z28
Old May 27, 2007 | 11:29 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Most likely one of two things....
When you surface the flywheel, it moves the clutch away from the slave.
There are shims available to fix that....020-.030 between the flywheel and crank.
Or, the disk is to thick. There are shims for that too, about .010 should do it.
I use this method quite often. They go under the mounting pads of the clutch.
theshackle
Aug 31, 2015 10:47 AM
19irocz85
Aug 26, 2015 07:54 PM
neekolzun
Aug 24, 2015 04:59 PM
smooth
Aug 18, 2015 06:34 PM
rsrmoore
Aug 7, 2015 08:44 PM
