Liquid on rear wheel?
Old May 28, 2007 | 08:19 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
I think i have a busted rear end wheel seal or something. there is a liquid, that looks like rear end fluid, that is leaking from the center of my wheel down to the ground. what is that and how do i fix it?
Old May 29, 2007 | 06:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Liquid on rear wheel?
You might check the brake line as well as the banjo fitting for leaks. If not, the seal may be the culprit. Replacement involves pulling the axel.
JamesC
Old May 29, 2007 | 08:40 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
yep, turns out it was the rear seals. i had the car inspected today and i had to replace them and the rear pads cause the liquid was flowing into the brake pads. thanks for the help.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
