Driveshaft won't come out
Old May 31, 2007 | 03:06 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Hey guys, I went to pull my driveshaft today so I removed the four retaining bolts, but I can't get the driveshaft out, is there anything else I need to do?
Old May 31, 2007 | 04:20 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Driveshaft won't come out
Make sure you mark both ends of the driveshaft in relation to the transmission tailhousing and the pinion yoke.This will make it easier when reinstalling.With the pinion straps removed you will have to slide(slip)the driveshaft yoke back into the trans to get the driveshaft to clear the pinion yoke.You may have to gently pry the driveshaft out of the pinion yoke.Be careful with the tail housing seal when removing/installing the driveshaft.Also you may get some transmission fluid seeping out when you pull the driveshaft.And if you are reusing the driveshaft/u-joints run some tape around the pinion end u-joint to retain the caps.Hope this helps.
Bubbajones_ya
Oct 25, 2015 08:01 PM
loud91rs
Oct 5, 2015 10:05 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
