fbody 700r4 vs. other versions
Old Jun 2, 2007 | 10:30 AM
BlueSmoke's Avatar
Car: 91 RS Camro Ttop
Engine: 5.0 LO3
is there a difference between f body versions or say 2wd pickups or caprice classics so on so forth. Mine is slipping at wot but doesn't through normal driving. I would like to have one to install to drive as my daily driver while I rebuild mine with shift kits and such. I just need to know if the versions are the same or if there is any differences between gear ratios and such. My car is a 91 LO3.
Old Jun 2, 2007 | 10:59 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: fbody 700r4 vs. other versions
The V8 versions are all basically the same.The V6 version has fewer clutch plates(among other things).The '87 up stock versions have improvements/modifications to clear up weak points.The bellhousing pattern is one of the main differences with non-Chevrolet motor applications.You will probably have to use the tailshaft off your 700 if you use one out of something other than a F-Body.Have you tried adjusting the TV cable?
Old Jun 2, 2007 | 11:38 AM
performabuilt's Avatar
You will have to swap your tailhousing as mentioned and there may be some minor issues with bolting up the converter cover some have different bolt sizes. And many F bodies came out with corvette servos for second where the truck did not you may want to consider swaping this over from your f body.
Old Jun 3, 2007 | 05:26 AM
BlueSmoke's Avatar
Engine: 5.0 LO3
I figured there were minor differences. Thanks.
I havn't adjusted tv cable but I'm pretty sure it's the transmission. My fluid is so black and burnt smelling as well. When I purchased it about 3 months ago I added the 2 quarts it was low but I don't think a fluid change will help 185k.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
3rdgenparts
May 21, 2016 11:50 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
