help please
Old Jun 5, 2007 | 05:57 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
help please
im puting a th400 i my 87 camaro i baught a new yoke for it i went to autozone and baught u-joints for it i got a u-joint # 2-1569bf at autozone that is a conversion ujoint but it dosent fit my yoke the part that is supposed to go on the yoke is to small the other side fits fine on the driveshaft. does anybody know what i can do or a part # that will work thanks the yoke is an outside clip.
Old Jun 5, 2007 | 09:06 PM
JayBoCC2's Avatar
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
Re: help please
you could do what i did and cut the end off a driveshaft that fits the th400 yoke u-joint and take it to a driveshaft shop and have it weilded on and balanced. since your gonna need a different (shorter) driveshaft anyway its worth it.
Old Jun 5, 2007 | 09:18 PM
82CAMAROBBC's Avatar
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
Re: help please
Get the u-joint for a 82 305 carb car. I dont remember if a drive shaft from a 82 -83 will work as stated above "Shorter"
