Urgent: Dont wanna get a ticket
Car: '91 RS
Engine: 5.0L gross *** tbi
my speedo jumps from the speed im goin back to zero.... and my rpm gauge is stuck past 7. is my cluster bad or some wires lose? did some "searching" and it looks like my speed sensor maybe? where is that on the tranny. i have a 91 3.1L 5spd.
thanks
tony
thanks
tony
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Urgent: Dont wanna get a ticket
Speedo sending unit is the circle with two wires coming out on the driver's side of the trans, in the rear corner.
Here's a pic of mine:
Car: '91 RS
thanks and if i make sure thats all the way in and everything is a ok then it should work? any advice on tach?
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
1st pull out the speedo sensor from the tailhousing of the tranny. Check the driven gear that comes out with the sensor. Also check the drive gear by chocking the front wheels, lifting the back tires off the ground, put tranny in neutral and have an assistant slowly spin the rear wheels. Miche need a mirror and a light to see the gear inside. Checking for broken teeth. There is the sensor, a buffer box under the passenger side dash and the cluster to also check as far as an electrical short/malfunction.
