Clutch part #
Old Jun 19, 2007 | 06:47 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Clutch part #
I apologize if this has been posted already but I am not in the mood to search the entire site just for a single piece of info.
Does anyone have the correct part number for a 1987 H code clutch? Its all i need to get my car going. I swaped an 84 G code 305 for the 87 H code bec the G code was blown. When i did the swap i realized that the G code flywheel wont fit so i discovered that the flywheel for the 87 was twice the size of the 84. Upon discovering this i also know i need to switch out the clutch as well. But I want to make sure i have the right part number before I put in my order because of the motor being a combination of the HO and normal 305.
Again I need the part number of the clutch for the 1987 H code 305 and It should mate up with the bigger flywheel. (Why they made it bigger only god knows)
Old Jun 20, 2007 | 09:13 AM
Re: Clutch part #
They didn't.
The flywheels for these cars are ALL the same size. No other size flywheel will fit. If you have a flywheel that's bigger, then it's not the one for one of these cars, and it WILL NOT work. You MUST get the right one; the bell housing WILL NOT go back on over a larger flywheel.
However, a 1987 motor has a 1-piece rear main seal, but a 84 motor has a 2-piece rear main seal; and the bolt pattern on the back of the crank is different. So your 84 flywheel won't fit your 87 motor either.
The same clutches fit all these cars with T-5s, from 83 to 92.
Sounds like you need a clutch for 83-92 V8 Camaro/Firebird T-5, and a flywheel for 86-92 V8 Camaro/Firebird T-5.
I suggest this clutch http://store.summitracing.com/partde...CTF%2DDF161056 and this flywheel http://store.summitracing.com/partde...t=CTF%2D700170
Old Jun 20, 2007 | 02:52 PM
Synful's Avatar
Re: Clutch part #
They didn't.
does an 88 motor have a 1 piece rear main seal?
Old Jun 20, 2007 | 03:01 PM
Re: Clutch part #
If it's 86-up, yes. 85-back = 2-pc, 86-up = 1-pc.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
rsrmoore
Aug 7, 2015 08:44 PM
