Tranny leaking when parked
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I replaced the transmission and when the car is running it does not leak but after it is parked, the next morning there is a half a quart of fluid on the floor. I have taken the pan off and reinstalled it and I cannot see how there is anyway it can be leaking there. Can the fluid be leaking from the fill tube if it is not fully seated? Will the fluid get that high when the car is off? Is the bolt that holds it accessable from the engine compartment or do I have to get at it from underneath?
Re: Tranny leaking when parked
Yup, fill tube seal.
Yes the level gets that high when parked.... unless of course it's all already leaked out below it.
IIRC the bolt that holds the fill tube on is the upper bell housing bolt on the right side of the motor; probably easier to get to from underneath. You may find either that the seal got munged during install (happens alot), or that the tab that the bolt goes through is bent, and not holding the fill tube all the way down.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
it could be anything
jut becaus eits not leaking when its runnign doesn mean that it isnt when youre driving
youll ahve to get under the car with a rag and a light and wipe off tranny fluid and look for the leak
start with the tube seal yeah
could also be speedo carrier seal
front seal
rear seal
governer cover seal
probably not loose tranny line since you say it doesnt leak when running
youll just have to look and see
no one here can
good luck
front seal
rear seal
governer cover seal
no one here can
good luck
Car: 92' RS
Engine: LO3
front seal
rear seal
governer cover seal
no one here can
good luck
front seal
rear seal
governer cover seal
no one here can
good luck
or the TV cable seal is wrong/installed improper and will cause about the same leak.
