trying to adjust my hurst quarter stick shifter
Old Jun 23, 2007 | 06:53 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i installed a hurst quarterstick shifter in my camaro which has a 700r4. im having a hard time getting the shifter to shift the trans in all the gears. the trans is fine. i can shift the trans into all the gears with out the shifter attached. its almost as if the shifter itself does have enough throw to it. i also cant get the neutral safety switch to work on it. if i put the shifter into park it will go into all the gears except for first, but if i put the shifter into the position for 1st and push alittle on the leaver on the trans it will go into gear. or i can get it to go the other way around(have it go into 1st but then it wont go into park). ive tryed adjusting it as much as possible and i dont seem to get anywhere. has anyone else had this problem. is there maybe another adjustment that im not seeing. any help would be great. thanks alot
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
