serious problem
Old Jun 18, 2007 | 09:31 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
How do you well reinstall your tranny ?
E D I T !!
maybe some replies to this one
Car starts, backfires like crazy, but here's the problem meant for this board:
I noticed I must have installed the transmission cable or something wrong. I can't move the shifter down to first nor second gear, so the cable which connects to the selector on the transmission must be installed wrong.
What did I do wrong and how do I fix it ?
Old Jun 19, 2007 | 08:49 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Re: serious problem
OK, so the car starts, but it moves forward, so obviously somethings way off.
Guess the car isn't going into Park or Neutral, so that would hmm explain why I can't set the timing properly.
So... once again .... how do you reconnect the cables to the tranny the correct way ?
Old Jun 19, 2007 | 09:02 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: serious problem
1. disconnect shifter cable from lever at tranny by removing the nut.
2. move lever on tranny all the way forward to obtain park
3. move lever on tranny towards back of car 2 clicks to obtain neutral
4. move shifter inside car to neutral position
5. reconnect cable. hold lever with hand so it doesn't move while tightening nut.
this should get it real close if not right on the money.
Old Jun 19, 2007 | 09:05 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Re: serious problem
ah ok
am i also correct assuming car wouldn't be able to have timing set right with est disconnected if it was in the wrong gear ?
Old Jun 19, 2007 | 09:12 PM
87zjeff's Avatar
Re: serious problem
yes, the tc being engaged will put a slight load on the motor.
Old Jun 19, 2007 | 11:47 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Re: serious problem
ok
Old Jun 20, 2007 | 12:45 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: serious problem
i always just turn the shift shaft all the way to park and put the shifter into park and hook the cable up
never a problem
good luck
Old Jun 23, 2007 | 02:28 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Re: serious problem
Is there any way one can loosen up the cable in order to get a bit more slack ? Having problems pulling it far enough to get it in the lever.
Old Jun 23, 2007 | 08:06 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Ah **** !!
Inside the console, the shifter cable. Now if you can see the inside cable, but after the bracket you can see a bunch of thick wires surrounding the inner cable, that means the shifter cable is broke/damaged, am I correct ?
Here's a pic I borrowed from another thread, however mine looks bit worse, only the inside cable is intact.
http://memimage.cardomain.net/member...1_113_full.jpg
But would this also explain why it seems like it was a tiny bit too short ? I couldn't get it to hook up with shifter in neutral and tranny in neutral.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
