Tranny filter, possibly a good idea?
Old Jun 26, 2007 | 03:24 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Whats going on guys. When running a tranny cooler, would it be a good idea to run a canister style filter (almost like oil filter) inline before the cooler? Has anyone done this?. I was thinking that if something would happen to the tranny, it would prevent the debris from traveling to the cooler and ruining it. I've always been told that you should replace the cooler if the tranny goes out and there is alot of debris. And with my tranny cooler costing like $100 plus, its could save some money. Just curious on everyones input on this.
Old Jun 26, 2007 | 07:45 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Tranny filter, possibly a good idea?
If you blow a tranny, the cooler only needs to be flushed out, not replaced. The "in pan" filter does a good enough job of filtering the oil. Just change it every few years.
Old Jun 26, 2007 | 03:04 PM
Shagwell's Avatar
Car: projects.......
The in-pan filter is the only way to filter debris before entering the pump. A cooler is nothing more than a bent piece of tubing that makes several passes back and forth through a maze of wafer material that helps extract heat as air flow through. How would there ever be an issue with flushing out a piece of tubing? If you can't flush a cooler, then the trans case and valve body are junk after clutch/pump/other failure also.
specialized
Jun 18, 2022 09:26 AM
camaro11j
Sep 19, 2018 08:49 AM
db057
Aug 22, 2015 08:17 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
