87 chevy 3/4 ton 12 bolt???
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
can you make one of these rears work in a third gen? thanks John
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 87 chevy 3/4 ton 12 bolt???
It's too wide.
A truck 12 bolt isn't the same as a car 12 bolt.
Like any other non third gen diff, there's no easy way to attach a torque arm to it.
It will have a 6 bolt rim pattern.
By the time you're done trying to convert it to fit, it will be cheaper to just buy a bolt in diff.
Easiest reply, no.
Easiest reply, no.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
hi there
i started out on trucks, trucks are my specialty, i made myself learn so muh about them and i have owned over 100 of them now since 95 most all of from ''67-87, i have had everything, blazers, duallies, panel deliveries, burbs, 1.5 and 2 tons, and so on
http://www.ringpinion.com/DiffList.a...peID=5&Type=GM
randys ring and pinion info is almost 100% correct, but a few things are not accurate
asis the case with virtually all the sites out there with axle application info
3/4 ton did not use the 12 blt 8.875 axle
3/4 ton are 8 lug wheels hubs, as are 1 ton
34 ton used the 14 bolt FF 10.5" from 73-up
and the 14 bolt SF 9.5" from 81-up
some 88 and up 14 bolt SF 9.5" were 5 and 6 lug
but uncommon
if its a 12 bolt cover then its a 12 ton truck
all 12 bolt were 5 bolt or 6 bolt wheels hubs depending on the year and if it was 4x2, or 4x4
12 bolt was last used in 1982 under trucks and 72 in cars
although car 12 bolt are a different axle than the truck ones, they dont even share the same diff housing shape or pinion gear stem diameter
truck pinion stem diameter are smaller than the others, real tiny
a weak point, at only 1.625"
if it is 6 lug then it is one of the following trucks:
2wd before 1971 = C-10 and C-1500
1/2 ton 4x4 any year= K-10 and K-1500
88-up 3/4 ton light duty= C and K-2500
if you were to use a truck axle then i would get a dana 60 rear from under a 72 and older 2wd 3/t ton in which are very comon and are ratio 3.54, 4.10, and 4.56 you can get them alll day long for 150 bucks and almost every one of them are POW-R-LOK equipped in which is badass
but they are all 8 lug full floaters so you would need to convert it from the hubs out
so a chrysler dana 60 would be easier, but ratios are who knows what
and even so none of these axles will go under a TG F body
unless you are a good fabricator/planner/welder and have a fat wallet to buy special axle shafts and so much more
but uncommon
Transmission: t56
thanks guys I guess it is not worth the hastle
LT1Formula
20
Nov 14, 2015 12:02 AM
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
