lt4 hot cam
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: lt4 hot cam
it will run fine on carbed motors. but you'll need to get the heads machined and setup with proper springs to handle the lift numbers. its .525 with the 1.6 rockers and .492 with the 1.5's i believe. stock heads usually only go to .480
1988iroc350tpi
Aug 14, 2015 07:52 PM
