th350 install question
Old Jul 1, 2007 | 10:27 PM
zot_man's Avatar
hey tried the search function(3 times) to no avail so im asking here i will be in the next week or so be installing a th350 into my 91 rs my question is which trans mount will i need the 700r4 or th350 i get conflicting answers from trans guys i know around here any help is appreciated thanx
Old Jul 1, 2007 | 10:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: th350 install question
The transmission mount isn't specific to the tranny however the tranny crossmember will need to be modified. The TH350 mount sits about 2" farther ahead than a 700R4. Since there were never any factory TH350's put into third gens, you'll have to modify the crossmember or buy an aftermarket one.
If you're still using a factory torque arm, nows a good time to upgrade. You can buy a Spohn torque arm with a tranny crossmember designed for a TH350. The crossmember/torque arm package also moves the torque arm mount to the crossmember since there's no place to mount it on a TH350.
Old Jul 2, 2007 | 12:18 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
or find a TH200C crossmember
if possible
glad my 82 was TH200C
or you could just make a mount extender out of a plate of steel
simple
all you need is four holes in it and youre good to go
this is what i would do if i were to put a th50 in place of a 700r4
simple easy and quick and cheap and it will work just fine no problem
all you need is a torch or saw, and a drill
and a piece of steel
search feature is broken for a good week or longer,, go look in the site boards there is a thread about the search feature being down
good luck
Old Jul 2, 2007 | 12:44 AM
AlkyIROC's Avatar
Car: 87 IROC L98
For the short time that I had a TH350, I simply welded on a plate extension for the mount.
Old Jul 9, 2007 | 01:36 PM
Tmaloney's Avatar
Car: 87 Z-28
Engine: 85 355 4-bolt
Transmission: 77 TH-350
Axle/Gears: 9" Currie w/ 3:70
Zot_Man
I have a B&M 350 install kit w/torque arm adapter for sale if you are interested. Bolts a 350 in with stock crossmember and rubber mount.
Also have a B&M ratchet shifter from my 87 Z-28.
Tmaloney
Old Jul 25, 2007 | 07:57 PM
HeavyChevyLT4's Avatar
yo tim did u ever install that b&m bracket cuz i cant figure how that torque mounts to the backet itself if anybody know tell me plz.
Old Jul 26, 2007 | 02:03 PM
Tmaloney's Avatar
Car: 87 Z-28
All I did was grind the rivets off the stock rubber mounts and bolt them to the B&M bracket. It was 12 years ago, but I remember that I did not need any parts other than the ones in the kit and the stock rubber mounting pads.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
