12bolt vs 9 inch?
Old Jul 4, 2007 | 06:37 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
12bolt vs 9 inch?
tried searching, but no luck. I think I can get a complete 12 for 2500, I'm kinda lost on this. going to need to hold 500 hp and a 3300 lb car.
Old Jul 4, 2007 | 07:22 PM
rlane5's Avatar
Re: 12bolt vs 9 inch?
A 12 bolt will stand up to 500 hp easy and a 9" will stand up to 500+ hp stock
moser and currie make direct bolt in for an F-body
Randy
Old Jul 4, 2007 | 07:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Both are equally strong. Both can be upgraded to be stronger although the 9" can be upgraded far more than the 12 bolt. Both have their advantages and disadvantages.
It becomes a personal preference. What do you want under the car? Neither will be a bad choice.
I run a 9" under my car.
Old Jul 4, 2007 | 11:07 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
I like the 9 inch personally. Your gonna shell out a bunch for both, so I'd suggest looking on ebay for a 9 inch since they have great deals on em there.
Old Jul 9, 2007 | 05:31 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
I run a 9". It was custom made for my car. Cost about 3000.00. I run Moser 31 spline axles with a Moser full spool and Richmond 4.11 gears.
Old Jul 9, 2007 | 07:03 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
12 bolt rears are a little more efficient than a 9in., but the 9in is stronger. Either one is plenty strong enough for 500HP and a lot more, especially when you go with an aftermarket unit like Moser, Curry, Strange ect.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
