Couple of questions on the tech article about beefing up the stock rear?
Car: 1986 firebird
Transmission: THM350
I bought my firebird with the v6 to v8 swap done half way, I finished what the guy started, i got the correct front springs, and corrected his wiring.
but Im putting in a SBC 350 I built, it should make about 380-390 HP at the flywheel.
So im looking into building my rear end to take this. but I know nothing of the rear end, is it a 7.5 or 7.625?
in the tech article it didnt list to much to make the rear end stronger, is it really that simple?
are there any steps I can do and take it a step farther?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Couple of questions on the tech article about beefing up the stock rear?
Somewhere around 85-86 GM upgraded the 7.5" ring gear to 7.625". They both fit on the same carrier so even the newer 7-5/8" diffs are still called 7-1/2" diffs.
No matter how much you beef it up, you still have a tiny ring and pinion. Price out the cost of new 28 spline axles, solid crush sleeve, rear cover with bearing cap supports, the cost to weld the tubes and you could almost buy the bolt in 9" housing with axles. You'll still need a center section with gears and carrier but you'll be getting a stronger diff for only a little more money.
The first 7.5" ring and pinion that you break will eat up the extra costs.
Of course I also ran low 11's on a beefed up 10 bolt. The only reason I switched to a 9" was that I installed a transbrake and knew the tiny gears wouldn't handle the shock of a transbrake launch.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
I went 12.50s with a stock rear and a 5 speed. An auto car wont shock the rear as bad so it may last longer. My motto is to not fix it until its broke.
84z96L31vortec
Aug 10, 2015 08:27 PM
