9-bolt axle codes
Car: 1985 Trans Am
Engine: Chevrolet 355
Transmission: Borg Warner W.C. manual cog
Axle/Gears: B W 9-bolt 3.45 Limited Slip
9-bolt axle codes
Ok ,I know this will sound dumb ,but i can not locate an axle code on either of the 9-bolts i have .I have scraped with a wire brush on the frt. of the rt. axle tube in the area between the backing plate and lower control arm mt. and near the ct. section. One is an 85 drum and the other is an 88 disc brake . Do all 9-bolts have a code stamped on them? I work in a collision shop so i have located them on , say for example Chevy trucks no problem. Can anyone send me a picture of one , or tell me where they find them. Thanks
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 9-bolt axle codes
The 9-bolts I have seen have a tag bolted to the cover that has the ratio on it. If the tag is gone, the rear end has been serviced.
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
you can also pull the diff cover and check the ratio as its on the side of the ring gear.
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
