driveshaft difference(700R4-TH350)
Old Jul 12, 2007 | 02:33 PM
cuda71ss's Avatar
Car: 1986 Chevy Camaro
Engine: 5.7L 350
Can anyone tell me how much I need to lengthen my driveshaft? Originally had a 700R4, now swapped to TH350 with the 6" tailshaft housing. I already modified my crossmember. When I searched around before posting my question I found a lot of estimates, but no real measurements. I'm guessing my driveshaft needs be around 1 3/4" longer?
Old Jul 12, 2007 | 03:05 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: driveshaft difference(700R4-TH350)
http://transmissioncenter.net/700R4_Swap_Info.htm
this is swapping a 350 top a 700 but it will give you what you need
Old Jul 12, 2007 | 05:16 PM
cuda71ss's Avatar
Engine: 5.7L 350
I called my local machine shop and got a price for a longer driveshaft and it came to be over $150! Is it just me or is this really expensive? Is there ANY other way I can come across a longer and correct length for less money?
Old Jul 12, 2007 | 07:42 PM
performabuilt's Avatar
Well I have gone to salvage yards and did the measurement thing , You need a shaft 3 inches longer than you have now, Would have been easier in that respect if you had gone with a 9 inch tail 350 for obvious reasons.
Old Jul 12, 2007 | 09:10 PM
toms84ss's Avatar
Yup, about 3 inches longer. $150.00 is not expensive for a new driveshaft. Remember this will be straight and balanced. Well, it should be anyway. Should have new U-joints in it also. You get what you pay for. Sometimes there are no cheap ways. only other solution is to grab a tape measure and head to the junk yards. You might find one long enough. And if your lucky, it may be straight and have half way decent U-joints. But then again, it may not. How much is your time worth?
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Numbah-1
Sep 12, 2015 08:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
J.C. Denton
Sep 8, 2015 05:35 PM
