t56 slave installation
Old Jul 14, 2007 | 11:33 AM
wildstar's Avatar
Car: 1984 L69 Trans Am
Does anyone know where I can find a photo of a correctly installed slave on a t-56 bellhousing? I have the parts but I'm not clear on how to mount the slave to the two studs. It seems like they were made deliberately long, perhaps to aid in adjustment?
I started with a 700R4 so clutch hydraulics are foreign to me.
Old Jul 14, 2007 | 01:08 PM
d10pins's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.70
Re: t56 slave installation
do you have the spacer for it??
Old Jul 14, 2007 | 11:59 PM
wildstar's Avatar
Uhhhh...... no? Didn't know about the spacer. Is that a dealer item?
Old Jul 15, 2007 | 07:13 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
there difficult to find, there are 2 things you can do, hunt through the boneyards for one, or bring your slave cylender to a machine shop, and have one made out of barstock in the same shap as the end of the slave cylender, that's what I had to do, cost me like $10, it is 1.95" in length if you want to go that rout
Old Jul 15, 2007 | 03:04 PM
wildstar's Avatar
I did a search for slave spacer and found the part number: 12523315. Gosh, there's so much to know about this swap - someone ought to write a book on it.
BlackphantomZ28
Aug 31, 2015 10:29 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
