which converter better?
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
which converter better for the money or best for my car?B&M Tork Master Torque Converters 3000 for $269.99 or B&M Holeshot Torque Converters 3600 for $429.99. i want the best bang for the buck. my cumbo in sig
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: which converter better?
whats the duration on the cam? do you street drive it alot?
if you drive it alot i'd stay with the 3000 stall. 3600 is for a hot 350 build
duration at 50 224 230. Just around town on weekend.
Car: 89 Iroc-z
Transmission: TH400
my buddy had a much milder 350 in his truck and used a 3500 stall. vortec heads/ performer rpm, 750cfm carb, LT1 cam. around 350-360hp. i'd stay 3600 wouldnt be too bad but maybe something abit smaller would work like a 3400.
sounds like a good combo tho. those heads and compression with that cam should make some power. i think possibly a 3600 stall would work for that combo...but hopefully someone else would come in here and give some advice. I'd rather have alittle less converter than too much.
and especially with 4.10 gears out back in a 350 trans. 3000 may work fine for that. its a ton better than 2200 stall
cam is a bit small for anything over 3k stall speed
- personally I wouldn't buy B&M crap. I save my money and buy something that's actually going to hold up. - "If you can't afford to do it right the first time can you afford to do it again?"
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
i havent heard anything bad about Raptor converters........
Car: 2000 BMW M5
The B&M has no lockup clutch. I would never use a 700R4 converter without lockup for street driving. They took the cheap and easy way out making that converter.
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
The BEST converters on the planet!!!
http://www.ptcrace.com/street-torque...f0b6b710f764d8
If im not mistaken you can get that unit at any stall speed you want.
Give them a call they are a great bunch of guys. Have used many of their units in various applications from street/strip to outlaw 10.5. They will ask ya a hundred question about the car to be sure they build you the rite unit.
The shaft you have listed will call for about 2800 stall. Keep in mind to that the trans will run MUCH hotter with more stall, so get a GOOD cooler on that puppy
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
