major problem who can help
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
My transmission mount went and along with it the threaded part the speedometer cable connects to on the transmission snapped clean off.
where can I get this part
how is it changed with transmission in car
Since I have converted my 84 T/A to fuel injection I have to use a VSS at the tansmission that fastens to the transmission and then the cable connects to it causing the whole assembly to be rather bulky this is the reason it snapped when the trany mount went. Is there a drive gear sleeve that has an integral VSS so I can eliminate this bulky set up?
thank you
jeff
thank you
jeff
