Attn Probuilt/Tranny Gurus -WOT downshifting problems
Old Jul 17, 2007 | 11:25 PM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
When I am on the highway at 65-75 mph and I floor it while in overdrive the car will shift into second past redline. Redline is at 5000 rpm in my car and sometimes it will downshift past 5500 rpm. I have had a TransGo Stage 1 shift kit, Corvette Servo, and .500" boost valve for 2 years on my 91 GTA without a problem until this year. My car has 119,000 km (74,000 miles on it and the tranny has never been rebuilt to my knowledge).
Last month I took the TB bolts off to replace the IAC housing and I left the cables attached to the throttle body. I also replaced the busted stock tranny mount with a Prothane one. I have adjusted the TV cable on a few occasions as per the instructions in the tech section but I still have the problem. Also, this does not happen everytime I floor it on the highway. Does anyone have any ideas on what could be the problem? Thanks.
Old Jul 18, 2007 | 12:06 AM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: Attn Probuilt/Tranny Gurus -WOT downshifting problems
mine did something like that and the problem was the tachometer started reading way off.
Old Jul 18, 2007 | 01:31 AM
Synful's Avatar
wierd.
mine did that when i got it but after a while it stopped, never figured it out for certain. only thing i ever messed with was the kickdown cable at the throttle was disconnected for a LOOOONG time, by accident, and then reattached and it was working fine.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
