C'mon folks someone has had to have this problem
Old Jul 18, 2007 | 08:22 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Who has had to remove the cover/case on the 700R4 that the speedometer cable is threaded to? My threaded portion snapped off and I need to remove the portion that is left while tranny is in car.
next..where do you get the new part?
thx
jeff
Old Jul 18, 2007 | 09:28 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: C'mon folks someone has had to have this problem
http://www.google.com/products?q=700...oogle&ct=title
Here is what you are looking for, i would go to the dealer, its called speedometer gear housing. It has 1 bolt holding the housing in, then take out the plastic gearshaft out of your old housing it has a small o-ring and retainer clip and lubricate both new o-rings with atf and reinstall, if you have changed tire sizes and want your speedo correct now is the perfect time.
Cooter
Old Jul 19, 2007 | 05:30 PM
jjlabinski's Avatar
Engine: shinny 350
thanks!
I have all the parts I need on order and I have to remove the tail section of the transmission to get the busted housing out.
jeff
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
TrevinE
Sep 14, 2015 03:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
