will my 84 trans am trans/bellhousing bolt to any 350?
Old Jul 23, 2007 | 08:56 PM
s10305's Avatar
I have a 87 s10 with the engine/trans out of a 84 trans am. the 305 is about to go and Im wondering will the entire drivetrain bolt up to any small block chevy? i want to replace the 305 with a 350.
I thought I remembered reading something about a difference between engines with one piece and two piece rear main seals?
I plan to use the trans, bellhousing, flywheel, clutch etc. that Im using now. probably replace the clutch with a new one since ill have it apart.
Old Jul 23, 2007 | 09:45 PM
toms84ss's Avatar
Re: will my 84 trans am trans/bellhousing bolt to any 350?
It will all bolt up to a 350 except the flywheel. That is the only thing that will need to change between the one piece and two piece rear main seal.
Old Aug 1, 2007 | 10:24 PM
s10305's Avatar
well the 305 has died, a hole in the side of the oilpan to prove it.
so if the 350 has a two piece rear main seal i can use the 305 flywheel correct? if it is a one piece I need a one piece flywheel?
Is there a difference in starters and the # of teeth with the different flywheels?
Old Aug 1, 2007 | 10:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes, the flywheel has to match the crank flange, which will vary with 1 piece and 2 piece RMS blocks. Your bellhousing will only fit the "small" flywheel.
theshackle
Sep 17, 2020 08:26 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
milk
Aug 10, 2015 06:26 PM
