Axleshaft swap
Old Jul 24, 2007 | 09:35 PM
bcacres's Avatar
Car: 83 Z28
Engine: Late 350
Axle/Gears: Standard 10 bolt 2.73
Axleshaft swap
Will an 88 axleshaft work in an 86?? Both are standard axles.
The reason I ask is that the 86 slid into a curb and bent the hub. Now the tire and wheel wobble. I have access to an 88 but was not sure if the shaft was the same in both years.
Old Jul 24, 2007 | 09:46 PM
TUNGSTEN's Avatar
Engine: 355
Axle/Gears: 3.73 Trutrac
Re: Axleshaft swap
It all depends on which rearend you have in your car and in the donor car. 10 bolt? 12 bolt? If both rearends have the same number of bolts then the axle should work.
Old Jul 24, 2007 | 09:58 PM
bcacres's Avatar
Car: 83 Z28
Engine: Late 350
Re: Axleshaft swap
both are 10 bolt
Old Jul 24, 2007 | 10:32 PM
novatuc's Avatar
Car: 1984 Trans Am
Re: Axleshaft swap
Now you just have to worry about 26 spline or 28 spline axles. I don't remember what year they switched to the 28 spline axles in the ten bolt but a quick search should get you the information.
Old Jul 24, 2007 | 10:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Axleshaft swap
Yes, they should both be 26 spline units.
Part way through 1989 they went to 28 splines, but it's rare in 1989, 1990 is the for sure year.
Old Jul 24, 2007 | 11:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Axleshaft swap
The 86 and 88, providing they're both 10 bolt diffs, will both be 26 spline axles unless a previous owner upgraded to 28 spline axles and carrier in either.. The 10 bolt also uses the same length axle on both sides so you don't need to pull one side out if the other is easier to access.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
