Driveshaft orientation
Old Jul 25, 2007 | 11:18 PM
wildstar's Avatar
Car: 1984 L69 Trans Am
I just finished installing a t-56 into my 83 T/A and am ready to install the drive shaft. Problem is, I removed it back in 1994 and didn't make any reference marks. Yes, I'm an idiot.
I took it to a machine shop today to get new u-joints pressed in. They said I needed to get it balanced because there's no way to make an educated guess, however, I noticed that there is a weight welded to one end...... would this be any clue as to its orientation w/ the yoke? Also, I'm not sure which end of the shaft should be coupled to the yoke.
Should I:
A - Take a SWAG at it?
B - Have it balanced for $110?
C - Buy one from a wrecking yard and just replace the u-joints?
Old Jul 25, 2007 | 11:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Driveshaft orientation
If it was balanced when you took it out, it'll still be balanced when you put it back in.
Old Jul 25, 2007 | 11:54 PM
wildstar's Avatar
But I took it apart and there are four different ways it could go back together.
Weighted end at the rear.
Weighted end at the front.
Weighted end at the rear w/ yoke offset by 180 degrees.
Weighted end at the front w/ yoke offset by 180 degrees.
I have a 25% chance of putting it back together the way it was. If I get it wrong, wouldn't that throw it out of balance?
Old Jul 26, 2007 | 12:11 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Chances are, not enough to make a noticeable difference.
Old Jul 26, 2007 | 01:08 AM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
The driveshaft isn't balanced with the tranny or rear end on so what difference does it make. Why would you buy a used one at a wrecking yard?
Old Jul 26, 2007 | 01:42 AM
wildstar's Avatar
But is it balanced with the yoke attached?
If so, I could see it making a difference...... hopefully not a noticeable one, like Apeiron said.
Old Jul 26, 2007 | 01:58 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, they're balanced with the yoke attached, but the yoke itself is a fairly well-balanced piece.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
