Kick down head ache
Old Jul 27, 2007 | 09:26 AM
Horrible01's Avatar
Car: 91 camaro rs
Engine: 350 sbc
Transmission: b&m 350
Axle/Gears: borg warner 9 bolt
Kick down head ache
For some reason the kickdown lever or switch hook thingy is stuck.... anyone knows what would cause this and whats the best way to fix this problem
Old Jul 30, 2007 | 04:46 PM
Shagwell's Avatar
Car: projects.......
Re: Kick down head ache
pull the pan and free the TV valve - also, it is NOT a kick down cable, and should never be used as one. It is a Tv cable which controls the TV valve which controls pressure in the trans. There is only one proper setting for it, shift points are tailored by the governor and the location/size of the holes in the TV valve sleeve. - If the cable is set improperly it can/will lead to the early death of the trans.
do a search before posting - many comon things have been covered so many times that few people will post replies.
Old Jul 31, 2007 | 09:09 AM
Horrible01's Avatar
Car: 91 camaro rs
Engine: 350 sbc
actually i got it going I should have posted somthing to indicate that. Also i have th350 transmission which i should have also mentioned so from what i understand its a kickdown cable not a tv cable..... From past experience i found out the hard way that a TV and kick down cable are 2 differnt anamals lol. <- acutally no LOL cus that **** was not funny.
Jake_92RS
Jan 28, 2020 10:37 PM
tcflint
Sep 14, 2015 04:55 AM
fasteddi
Sep 2, 2015 10:29 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
tc7761
Aug 30, 2015 09:45 AM
