BW 9 bolt 3 series carrier
Old Jul 27, 2007 | 03:32 PM
TMZIrocZ350's Avatar
Car: 89 IROC
Engine: 5.7L
Axle/Gears: 3.70
Hey guys,
Have an 89 IROC with the BW and 2.77 gears. I am looking to upgrade, but can't seem to find the 3 series carrier for sale anywhere. I have found the gears, 3.70's. I know it is going to get pricey, but does anyone have and leads for me.
Old Jul 27, 2007 | 03:57 PM
Demon355's Avatar
Re: BW 9 bolt 3 series carrier
I'm in the same boat. How much were the gears? Rebuild kits?
Old Jul 27, 2007 | 04:53 PM
Car: 89 IROC
Engine: 5.7L
Axle/Gears: 3.70
Demon355,
Tis what I have found so far:
http://www.drivetrainspecialists.com...ner/index.html
They have the ring and pinion as well as rebuild kits.
This is another site that carries it, but have to call for price:
http://reiderracing.com/gm734.htm
Still no luck on the carrier though. Anyone out there looking to sell one let me know.
Old Sep 23, 2007 | 11:50 AM
TransAM Joe's Avatar
I have a 9 bolt 3 series carrier for sale but no ring and pinion gears, reused them on my new carrier and 31 splined axels. Carrier was disassembled, cleaned, cones machined and shimmed, posi nice and tight (55 ft lbs resistance) about 8 months ago. Let me know if still interested. Ring and pinion gears for 9 bolt are not hard to find. Yukon and Motive make a 3.70 ratio for around $175, but if you want geniune gears they are about $400 and are available in Australia.
Old Oct 2, 2007 | 08:34 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
That carrier should have waay more than 55lbft if it is rebuilt properly. A tight one will be over 200lbft if shimmed tight and the springs are good!
Can't you find a whole axle somewhere with a 3 series?
Old Oct 2, 2007 | 08:47 PM
good catch there , should be 255 lbs. Tried to fix it in the previous post.
Old Oct 3, 2007 | 08:55 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Ha, that's a LOT better!
I spoke to some rebuilders in NZ when there on vacation...these are good axles. You set the posi's up tight, remachine the stock cones if required, use Redline gear oil with NO additive, they take lots of abuse. A tight posi will clunk and bang, but the louder the better if you can stand it. It means it is working. If the posi gets loose, shoot some Redline Heavy Shockproof gear oil in there..
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
