Torque Arm Mount
Old Jul 31, 2007 | 06:51 PM
Tenom's Avatar
Car: 1989 GTA
Axle/Gears: 3.23s
Torque Arm Mount
I'm doing a 700R4 to T56 and noticed in the "answers to questions that aren't normally asked" thread that the torque arm mount for the 700R4 setup won't work and that I would need one from a 4th gen. Does anyone know the part number for the mount? I've looked online for the part but I keep getting ones that fit 85-97 which doesn't make sense.
Old Jul 31, 2007 | 09:14 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: Torque Arm Mount
i would think saying all was stock and its just a tranny swap it should fit. Now there is a differance in the way the lip ont the touq arm tip faces in differant years, mid 80's some where change
Old Jul 31, 2007 | 09:42 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
All the torque arm mounts for the manual shift transmissions were the same for the 5 and 6 speed up through '97. The one i have came from a t-5 and it bolts up fine. auto's are different mount both 3rd and 4th gen.
Old Jul 31, 2007 | 10:21 PM
Tenom's Avatar
Car: 1989 GTA
Axle/Gears: 3.23s
Thanks, now I just need to find a site that sells them and specifies if it's for a manual or auto. Local Pontiac dealership wasn't much help.
Old Jul 31, 2007 | 10:37 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Don't run a stock torque arm, get an aftermarket crossmember mount or a jegs brand type mount instead of spending the money on something that can break tailshafts off your trans.
Old Aug 1, 2007 | 12:38 AM
Tenom's Avatar
Car: 1989 GTA
Axle/Gears: 3.23s
Can someone recommend one for what i'm doing?
Old Aug 1, 2007 | 01:03 PM
xpndbl3's Avatar
Car: 1984 Z28
spohn, BMR, alston, jegs brand, etc etc. There are tons out there and they all are basically doing the same thing.
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
