9 bolt or '92 10 bolt with pbr calipers
Old Aug 4, 2007 | 08:11 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
i found a '92 10 bolt with posi,disk brakes, pbr aluminum calipers, and 3.42 gears for 450 bucks. i can find a 9 bolt with basically the same gears & posi for under 200.
both are stock but the 10 bolt comes with master cylinder & proportioning valve for rear disk brakes.
either way i would be miles ahead of my 10 bolt 2.73 peg leg!
opinions?
thank's!
Eric B
Old Aug 4, 2007 | 08:35 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: 9 bolt or '92 10 bolt with pbr calipers
my advice...go to the junkyard and get the LS1 rear end...they cost the same as the 92 rear end....if i had the $ i wouldve gone with LS1 rear end, but i was stupid and i have to pray that my posi will hold out......9 bolt parts are pretty hard to come by
Old Aug 4, 2007 | 08:43 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
i have 15" rims. thought i read somewhere there was a problem with that?
i'll search on that.
thank's for the quick reply!
Old Aug 4, 2007 | 08:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 10-bolt with PBR's is the way to go, IMO.
JamesC
Old Aug 4, 2007 | 08:54 AM
Car: 92 Camaro
Axle/Gears: S60 373
well if the gears and posi in the 10 bolt aftermarket go with the 92 10 bolt....
Old Aug 4, 2007 | 11:09 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
IMO don't waste your time with a 9 bolt.
Old Aug 4, 2007 | 11:26 AM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Engine: 5.0L TPI. Custom Tune
Transmission: 5 Speed/ Pro5.0 short /hurst stick
Axle/Gears: 1LE 10 bolt Rear/T2R 3.45 PBR/disc
I agree, 9 bolts are good if you are restoring a car to factory specs. I just dumped the 9bolt from my car and installed a 10-bolt with PBR brakes and earl's hyperfeel steel brake lines. While I was there, i dropped a Torsen T2R in there and the thing powers thru corners like it is on rails....
+11enty billion on the 10-bolt, PBR and T2R.
Old Aug 5, 2007 | 11:28 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
10 bolt on it's way home!
thank's guys!
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Jlanz55
Sep 6, 2015 07:28 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
