New clutch / T5 replaced......questions.
Old Aug 5, 2007 | 11:37 PM
Sean2857's Avatar
Engine: 383 stoker in progress
Transmission: Soon to be a TH400
Okay, first off. My clutch was starting to slip last week so i decided to replace it and i also decided to replace my slave cylinder and transmission because the syncros in 3rd and 4th gear were shot. i just got the car back together this afternoon and i took it out for a ride around the block a few times. i dont know if this is normal but the clutch pedal is extremly easy to push in. i had to apply a considerable ammount of pressure on the old cluth pedal but this one, i can just use the weight of my leg for it to go down. another thing is the new clutch seems to catch at the top of the pedal....is that normal?.....when i had the car out on the highway tonight, i noticed a burning smell. kind of like brakes being over worked. is that normal for a new clutch? other than that the car seems to be running and driving great.
Old Aug 6, 2007 | 06:29 AM
Re: New clutch / T5 replaced......questions.
Some clutches are just easier to push than others; the Centerforce Dual friction for example.
Sounds to me like it's working OK. Most of the assembly mistakes that people make will make the clutch pedal seem like it needs to be pushed an additional 3" or something to make it release. If yours is releasing well within the stroke of the pedal, it's probably fine.
Old Aug 6, 2007 | 10:53 AM
Sean2857's Avatar
ok i was just making sure. the centerforce dual friction clutch is what i put in there haha. seems to be working great. :-D
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
