Ok, someone Please answer this..
Old Aug 7, 2007 | 07:55 AM
ryan77's Avatar
Car: 89 Camaro, 00Xtreme s-10, 89 Buick "Party Ave"
Engine: 305tbi
Transmission: 700r
How do I manualy(by toggle switch) lock the torq- converter...my ecm isn't locking up in fourth gear,(engine/tranny/ecm swap from fire bird with electronic spedo to a camaro with a mechanical spedo, now the comp is'nt getting the speed signal to lock-up) I've been advised against the vaccume type lock-up kits for the 700r's, and I want to drive this car, so what is the quick drive it now fix, I know the ecm sends a grounding signal on the tan and black wire, and the red wire is ran thru the brake switch(to disengage I assume) but when i drive the car there is voltage on the tan/black wire, and I don't want to toggle it to ground if I am unsure, please help!!!! I know this is simple and many of you all have done this, please explain it just one more time....help a brotha get a trhid gen back on the road.
Old Aug 7, 2007 | 08:59 AM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: Ok, someone Please answer this..
put a toggle switch on a ground wire to pin 'F' (top left) on the ALDL connector. its in the tech articles.
Old Aug 7, 2007 | 09:40 AM
ryan77's Avatar
Engine: 305tbi
Transmission: 700r
Thank You...I will try that, I never did find it when people say tech articles is that on the main page??...can you give me a link to it.....thanx again!!!!
Old Aug 7, 2007 | 09:48 AM
on the www.thirdgen.org homepage, you'll see a link on the left side called "Technical Articles"
Old Aug 7, 2007 | 11:25 AM
ryan77's Avatar
Engine: 305tbi
Transmission: 700r
thanx man, I can't believe I did'nt even see that
grngryoutmyway
Oct 18, 2016 05:48 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
