Where to put transmission temp sender?
Old Aug 11, 2007 | 12:36 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I was going to tap into a line running to a cooler but I think it'd be better to measure the temp in the transmission pan. It could probably double as a hole to drain the fluid if its at the bottom of the side of the pan. Any comments from someone familiar with transmissions? Good idea/ bad idea?
Old Aug 11, 2007 | 01:30 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: Where to put transmission temp sender?
Bang a hole in the ban, if you have room, and use a drain plug kit. The center is a 1/8 npt thread, and the sender will usually screw right in. I have done quite a few with no trouble.
Old Aug 11, 2007 | 11:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I drilled a hole in the pan and tacked a weld nut on the inside.
Old Aug 12, 2007 | 12:55 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
We used a drain plug kit for the sender we put into the 82.
just make sure that there is clearance for the sender so it doesn't hit the valvebody.
Old Aug 12, 2007 | 10:24 AM
Car: 86 T/A
Engine: HSR 355
Yeah that's my plan, I already have the parts.
jhawkeye
May 25, 2022 06:33 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
