What hole to put B&m trans lever in. HELP!
Old Aug 13, 2007 | 11:19 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I am using a B&M megashifter (ratchet) w/ a 700R4. The shifter can be set up for 3 or 4 spd. The instructions were obviously written for the 3 speed, but then they went back and added a few particulars for the 4 spd.
Although the instructions say use the front hole in the lever that mounts to the trans, I need to know from you guys that this is definitely the correct hole to use for a 700R4.
I lost the instructions. I found them online, but I clearly remember that along w/ the instructions in the box, there was a loose additional sheet that described additional info for what hole in the shift lever to use with what trans.
Thanks!!
Old Aug 13, 2007 | 11:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: What hole to put B&m trans lever in. HELP!
http://store.summitracing.com/instru...%2D80692%2Epdf
Old Aug 14, 2007 | 07:39 AM
Car: 2000 BMW M5
Yeah I already have that sheet. There was definitely another supplementary sheet that had more info on what the holes in the shift lever were for, but I can't find it anymore.
Old Aug 14, 2007 | 09:57 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
Use the front one.
Old Aug 24, 2007 | 04:06 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i vote for the front i have not had shift problems with it... yet
Old Aug 24, 2007 | 04:12 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
It is the farthest hole towards the front. End of story.
BRoss99
Aug 10, 2025 05:08 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
lakeffect2
Aug 23, 2015 08:44 AM
Leggman1
Aug 6, 2015 04:15 AM
