clutch-less shifting?
Old Aug 17, 2007 | 09:38 PM
Form88's Avatar
Car: 1988 Firebird Formula
Engine: 305 L03
I have a t-5 on an 83 T/A. Just curious if anyone shifts without the clutch, how and when its done, potential harm to the trans ect....
Jim
Old Aug 17, 2007 | 11:24 PM
Synful's Avatar
Re: clutch-less shifting?
how it's done: ramming the shifter into and out of gear
when its done: only at the most idiotic of times
potential harm to the trans: ummm.....destruction of the transmission
drive your car right please
Old Aug 17, 2007 | 11:26 PM
83Chevy__Camaro's Avatar
it only harms it when you grind it, if you know how to match the rpms right then its no problem, just a lot slower then shifting with clutch.
Old Aug 17, 2007 | 11:43 PM
Form88's Avatar
Engine: 305 L03
I know truck drivers do it with their 18speed+ trannies ever since they were made with synchros... I really dont have any intension on doing it. I was just curious if there would be any harm in trying given the proper knowledge.
Old Aug 18, 2007 | 12:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Shagwell will notice this thread and chime in, if not in a few days, you can PM him. He has done it with his WC T-5 (until it broke...)
Do a search with his name, he's rattled off how to a number of times, once very recently to me actually..... ok ok, i'll find the thread;
....... I don't know why, but I couldn't find it, sorry
Anyway, yea, when you're accelerating your engine is pushing on the gears, and it's hard to get out of gear (so you use the clutch), when you're decelerating your car is leaning on the back of the gears, so it's hard to get out of gear (without the clutch), when your engine speed is matched to the cars movement then it'll just pull out of gear harmlessly, you let the revs drop while holding it against the higher gear (lightly!), and it'll just pop into gear. Do this until you're comfortable doing it, and it doesn't make any noises. This will happen quite leisurely.
If you're doing this to go faster:
His suggestion was a few different ideas,
rev the **** out of the car until it hit the rev limiter, or torque peak, this way your engine won't be making enough power to keep accelerating, so you'll have a split second where your engine and car are moving at the same speed, so you can slip out of gear easily.... Let the revs drop a tad while holding it against the next gear, then mash the gas again.
That's the gist of it. I think this would be slower than just holding your foot on the gas while using the clutch (power shifting) - but that's probably because I know how to powershift somewhat well, whereas I have no idea how to do a clutchless shift with any kind of speed or efficiency.
A clutchless shift is easier on the drivetrain that a powershift, no shocking the drivetrain sorta thing, but it's harder on the engine if you're revving it up to the rev limiter (IMHO)
Old Aug 18, 2007 | 03:56 PM
Form88's Avatar
Engine: 305 L03
Make sense. Thanks for the info
Old Aug 18, 2007 | 08:39 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
18-wheel truck drivers do it because their transmissions are strong and designed to take the abuse.
T5's are not designed for that kind of treatment.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
