87 Camaro Killing
87 Camaro Killing
I have a 87 camaro Berlinetta with a 86 trans am engine and tranny (305Tpi, and a 4 speed auto with Od), my question is that whenever i drive my car around for about 15 minutes, pull in my drive way, and go to change gears it dies, the rpm goes under 500 and it just dies every time i shift it (except for neutral), it only does it after its been running it for a while, and I know the rear end is going out on it (it clunks, and the car lurches going in to drive, or reverse), and i was wondering if it is the rear end causing it to do this or what else could be doing this.
Any Help Would be appriacted, I know very little about trannys, except for how to install them
Tom
Tom
Last edited by masterhacker198; Aug 25, 2007 at 11:40 PM. Reason: Forgot something
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 87 Camaro Killing
Usually the "clunk" when going into gear is a torn up transmission mount. You will have to jack the tranny up to verify this because it will look like it's fine just from looking at it.
Sometimes a u-joint is shot when you get the clunk as well...
Any Idea Why Its Killing, and its not just a clunk the whole car lurches I should have mentioned that before sorry...
Iroc8t8
May 4, 2026 08:09 PM
