how far will my 10 bolt go
Old Aug 26, 2007 | 02:54 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
ok so for my setup i have a stock 10 bolt rear with 3.08 gears posi of course. on this i have lcas, and relocation brackets. my tranny is a stock 700r4 with a corvette servo. i also recently just added a set of m/t et streets. my question is with 300whp or more not sure with nitrous with spraying out of the hole will i snap my rear or or will then tranny and high gears save it?
Old Aug 26, 2007 | 03:16 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: how far will my 10 bolt go
10 bolt rearends were never a strong diff, and someday it will break with constant abuse.
Slicks and high rpm launches and traction will end the pain sooner than later.
I'm at 1.77 60fts with a diff cover and welded axle tubes, my time is coming
Old Aug 26, 2007 | 04:14 PM
Engine: LO3
i dont do high rpms launches. i only launch at like maybe 1500rpms and spray nitrous right out of the hole. i only would do it a few times.
Old Aug 26, 2007 | 04:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
I took a beefed up 10 bolt deep into the 11's before finally swapping in a 9" when I also installed a transbrake.
Old Aug 26, 2007 | 04:32 PM
87_TA's Avatar
I have gone 10.08 with a 10 bolt, moser axles, torsion diff.
Currently running deep 11s with 6 speed now, but have seen them go alot sooner though..
Auto will treat it well, May want to spray a few feet out just to get load on first,she will live for a while..
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
