ok seriously what do I need
Car: 85 Trans Am / 64 Chevy Nova
Engine: Turbocharged 355ci / 383ci
Transmission: WC T-5 / T10
Axle/Gears: 3.45 / 4.11
I would like both of the rear wheels to spin at the same time. I must have went through thirty posts trying to figure out what to do, however, all they did was explain what a posi was, and what limited slip was. I'm guessing that because Im doing one wheel burn outs is because I have an open rear end. I want to know what I could put in there so that both wheels will spin? Thanks for the help
Re: ok seriously what do I need
http://cgi.ebay.com/ebaymotors/REBUI...QQcmdZViewItem
I found that, could that be used? or something that is a locking differential?
Transmission: 4L80E/4L80E
You could use that, but if you have the original rear end, you have 26 spline axles. If you replaced the axles with 28 spline pieces, you could have a shop install that posi unit. It would also need 3-series gears (3.23 or higher number if stock).
Or, you could get this http://store.summitracing.com/partde...5&autoview=sku and install it yourself. Probably less than the cost of the posi, gears, axles, and shop install you would be facing with the eBay unit.
hey thanks alot, that seems pretty reasonable, my old man was telling me id need something thatll go for about 1400 to get it to work, i guess he was talking old school stuff. With this ill be one step closer to keepin up with his nova...
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
That ebay link is for what is called a "gov lock" posi, which in my experience are known for a 100% failure rate after time. Not that they quit working, but there are some tiny little pieces that will break, and eventually cause them to self destruct. If you search "gm posi" on ebay you will probably see a lot of those gov-locks for less money than an Eaton or Auburn style, and there is a very good reason for that.
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
"Positraction" (posi) is a Chevrolet tradename for a limited slip differential. The "carrier" component of the rear axle is what determines if it is a posi, or not. What you want is a posi carrier. Get an OEM carrier (Auburn?), or an aftermarket carrier such as Eaton , that uses either cone-type or friction disc-type "clutchs" that marry the axle shaft mated pinion gears to the carrier body.
Then you can wear out two rear tires instead of just one.
Bill
Bill
You DO NOT want the thing in that eBay ad!!!! That's the infamous Gov-Lock, aka Grenade-Lock, that is 100% GUARANTEED to fail spectacularly if used in combination with power, traction, and pavement. Just ask the S truck folks; they manage to tear them up with nothing but a 6-cylinder.
You need an Eaton N19663-1. Thunder Racing part # 185-19663-1.
You also DO NOT want an Auburn. Their reliability and customer service have been very poor of late. I strongly recommend staying away from them.
Any stock unit (Auburn as well) you find is likely to be worn out. Those have very weak clutches at best, anyway; not very effective.
just a thought, check your rearend, you might have a limited slip already, it might just be broke, i had one on my 87 that i didnt think was a limited slip till i took it to a local shop and they said if was just damaged and wasnt engaging, cost me $350 to have it fixed now it lays rubber like never before.
